checkyourmirror
Dec 31, 2025Aspirant
Main 960 in AP Mode doesn't show Satellites in Attached Devices over enet
I've been using my 960 in Router mode with two satellites backhauled over ethernet, and everything was working great. I could see the satellites in the attached devices. I switched over to using the ...
Dec 31, 2025Guru - Experienced User
Where is this switch connected?
What is brand and model# of this switch?
If you get a 2.5Gb supporting non managed switch connected at the RBR, then you can connect all RBS to this switch and will get 2.5Gb rates to the RBS.
checkyourmirror
Jan 01, 2026Aspirant
I will give that a try this weekend and report back, and curious what is it about a managed switch that causes the problem? I am using a low-end Netgear managed switch and like many wanted to keep the brand consistent to avoid problems like this.
- FURRYe38Jan 06, 2026Guru - Experienced User
What is the model# of this switch?
Managed switches introduce some traffic paths that are outside of the main operation path of Orbi systems. Been like this for while now. Only seems to effect when the satellites are connected thru the managed switch. Not seen with non managed switches. I've worked with NG on helping identify issues with Orbi systems and managed switches. NG finally came up with this KB article to help users with Managed switches and Orbi systems:
