MasonReed
Apr 02, 2025Aspirant
Manual update router updates satellites?
I have the RBR750 and two RBS750 satellites. I just performed a manual update on the RBR750 router, by uploading the chk file (7.2.7.15). When it restarted, I opened the two satellite web pages, and ...
MasonReed
Apr 07, 2025Aspirant
I don't know how that happened. I am kinda guessing that the satellites are reporting incorrectly, or the router is reporting them incorrectly. The auto update is turned off. I did not tick the satellite tickbox on the router update page.
Anyway, I just manually updated the satellites, just in case. I will update satellites first from here on.
Apr 07, 2025Guru - Experienced User
You can follow this PDF guide on how to best manually update a Orbi system:
Glad you got yours updated. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
