RiverboatGamble's avatar
Apr 17, 2026
Maximum number of 960 satellites?
I have an RBR960 with 5 satellites covering my main building. The router is running in AP mode.
I want to extend coverage into an adjacent building using the same broadband link.
I have purchased an RBR960 plus 2 satellites to cover the new area.
Does anyone have any guidance or suggestions regarding:
  1. adding the new equipment as satellites to the existing configuration
  2. configuring the new equipment as a separate network
I guess the fundamental question is how many satellites can be added to a single configuration?
Any advice appreciated,
Thanks
  • CrimpOn's avatar
    CrimpOn
    If the new 960 router and satellites are installed in the remote building, they create a separate network. It may be configured with exactly the same WiFi credentials (SSID/password) as the existing system and may be set up in AP mode which means that the primary router will assign IP addresses, but it will be a separate network.  The original 960 will have 5 satellites and the new 960 will have two.
    The main issue is how to connect the Ethernet WAN port on the new 960 router to the primary network.
