jkfromk
Aug 18, 2020Follower
Mixed backhaul on ax4200
Looking to purchase the AX4200 pack from Costco. I need to confirm that I can have the following configuration work:
Modem > Orbi Router with wireless connection to Orbi Satellite > Wired connection to orbi satellite in detached metal building.
I need to have the 2nd and 3rd satellites wired to each other since the metal building can't receive the wifi signal. Neither the 2nd or 3rd satellites would be connected directly to the router via ethernet.
Will this work?
Will this work?
1 Reply
Not sure if that will work, This is the supported wire connected RBS configuration:
