mrp12
Mar 29, 2021Aspirant
Mixed Backhaul on Orbi 750?
I'm having trouble getting a mixed backhaul (wired and wireless) setup working with the Orbi 750. I have been able to do this with an Orbi RBK50 system, and I understand that it should be possible with the 750. However, when I plug the ethernet cord into the LAN ports (as the diagrams show and as I've done with the RBK50), the 750 seems to stop looking for wireless satellites (although it then sees the wired ones), and it can't find wireless satellites to which it was formerly connected. Is there something I'm missing in the setup to get it to look for satellites on both ethernet and wireless?
Mixed works on Orbi AX. It's best to sync the RBS first, then ethernet connect the RBS after wards.
Is the RBS being directly connected to the back of the RBR or is there a LAN switch in between them ?
Also:
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. - mrp12Aspirant
The present setup is an orbi router with 3 wireless satellites, and the network connected to the WAN port of the router. These 3 satellites need to remain on the wireless backhaul. From my understanding, to enable a wired backhaul for the additional satellite, I need to move the ethernet connection to the router from the WAN to one of the LAN ports (does it matter which one?). Once I do that, the connections to the wireless satellites are lost. Sync-ing, rebooting, and moving the satellites right next to the router in various combinations does not seem to help them connect. It's as if the router just stops looking for them on the wireless backhaul. The router still allows an internet connectin through the LAN port.
In previous attempts, I have gotten the wired connection to work in this setup (without the wireless ones working). But for today, I'm just trying to do one step at a time so I'm focusing on getting the wireless connections to work.
Thank you!
Is your RBR in router or AP mode?
Just connect any of the RBS to the back of the RBRs LAN ports.The WAN is only used for the RBR to connect to the ISP modem in router mode or a host router when in AP mode.
