tmgrood
Jun 04, 2023Aspirant
Modem to use with RBKE962
Hello,
Has anyone got a suggestion on which cable modem to use with the Orbi RBKE962 system?
I use Xfinity and would rather buy my own equipment.
Thanks
- Hey Furry, thanks.
I should have mentioned it in my original post but I need one that accepts Xfinity voice. I do appreciate your quick response. Thank you!!
Check to see if NGs CM2000 modem is supported by XF.
- tmgroodAspirantHey Furry, thanks.
I should have mentioned it in my original post but I need one that accepts Xfinity voice. I do appreciate your quick response. Thank you!!Ok, the v version will be the one you want then.
Be sure you use a CAT6A STP cable between the modem and RBR.
Enjoy.
I use the Netgear CM2050V with my Xfinity service. This is the modem/gateway that includes the analog voice gateway feature that provides our home with telephone services. Been using it without any problems since last December.
- tmgroodAspirantThanks for your response.
I went ahead and ordered the CM2050V.
I appreciate your help and information. I've got the CM2000 on xfinity and it works great.
- Missed your reply but the cm2050v is a great option too with needing voice.
