Jcslam
Oct 23, 2023Aspirant
My Orbi Mesh WiFi 6 RBS350 Satellite always disconnected
I have my Orbi Mesh Wifi 6 RBK352 system with two satellites for three years already and they are running perfectly fine and very good before. Recently, I moved home and added a lot of smart devices, over 80 smart light pubs. I am not sure it is the cause or not, but the satellite always discounted from the Internet and showing red light. But some devices still connect on this satellite, so they are disconnected from the Internet too. I asked the technical support, they said my model can support 127 devices in each channel 2.4G and 5.0G, but when I told him my situation, he replied that I proved it cannot connect to too many devices and said it depends on the type of devices. I understand it, but most of my devices are smart light pubs, I don't think they consume many resources. I saw some people said FR may help, so I factory reset for the router and two satellites, it works for two days, but after two days, the satellites discounted again. I try to relocate the satellites location, but the situation won't changed. So, I want to post out to see anyone has similar situation or not, thanks in advance.
I tend to agree that even 80 smart light bulbs should present very little usage of the WiFi network. (Although I wonder how it is possible to have that many. My entire house has probably fewer than 30 total light bulbs.)
I wonder how it is possible for a WiFi device (such as a smart light bulb) to be connected to a satellite that has no link to the router. (magenta light)
What brand/model of bulb are these?
Is it possible to power them off with switches or are they 'hard wired' to electricity?
(reason: it would be interesting to see if removing them from the network causes the satellite to regain a connection when it is powered off and back on again.)
If the satellite is temporarily moved to the same room as the router and plugged in, does it get the "blue light" indicating a good connection to the router, and show up on the Attached Devices display as "Good"?
- JcslamAspirant
Hi,
Thank you for your reply. I have a lot of spot lights, so it cause many smart light pubs.
Sometimes, it show the magenta light, but sometimes it does not. I test it by getting my mobile close to the satellite and my mobile can connect to the wifi, but not the Internet, when I relocate my mobile to close to the router then the Internet connection is fine. If the satellite does not show the magenta light, then I can check my mobile was actually connected to the satellite by checking the device list, but ofcourse I cannot do so, if it is showing magenta light, it looks like still connect on it, as the behaviour is the same, but may be I am wrong.
I use enshine smart bulb. Yes, I try to turn them off, but it won't bring back the satellite, I need to restart them to make them have connection again.
I try to relocate the satellites, every time when I unplug and replug them, they are running fine and display "blue light", but they will disconnected later.
Now, I am using another brand mesh wifi system, so far has not disconnected issue, but Orbi has larger coverage and I believed that Orbi should be working fine too, so I will do further test.
Now, I face another problem, after I factory rest the router, it cannot connect to the Internet, I am sure the modem is fine, as my another router can use it and connect to the Internet.
I checked another post has similar issue and someone recommend reset it twice, I don't know why, but I will try it later: https://community.netgear.com/t5/Orbi-Wi-Fi-5-AC-and-Orbi-with/Orbi-AX1800-will-not-connect-to-internet/td-p/2187132
