chapotito
May 13, 2023Aspirant
My Orbi RBR750 runs at half half speed.
For some reason, my RBR750 is running at half speed. I am supposed to be getting 200 Mbps. When I connect the PC directly to the modem, I get 200+, when i connect the Orbi i get from 85 to 95, never really reaching even 100. i was not paying attention when this started happening. It is possible it happened when I updated the firmware in the router and the satellites. Anyone knows how to fix this issue?
As a complaint, the "Associated Products" should have the name of the product name. Even more when it is a required input. The product name on the Bottom of my router is RBR750. that name does not appear on the choices. I had to put what I think it was years ago when I bough it. But somehow I think it is not really.
Well, problem fixed. Change all the cables just in case it was the cables. . But I had to reset the Orbi to factory settings. I didn't want to reset the thing to original factory settings because there are a lot of things on wireless, not counting having to reset the three satellites. But that did it. I am back to 230 Mbps. Now I have to reset the satellites and reconnect the 5 security cameras, the thermostat, the 3 echos, two TVs, PS5, PS4 and i am pretty sure I am forgetting two or three other things that I dont remember. I hate it, but at least I am up to speed.
I rechecked and I am abou5t 90% sure the speed dropped right after I updated to the last firmware about three months ago.
You can check and see if its connecting at gigabit speeds.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- chapotitoAspirant
Firmware version V4.6.14.3_2.3.12
There is no manufacturer on the modem. It reads XB7 CM. I did some research and someone said it is an ARRIS TG4482A.
The LAN cable is a CAT6. When connected directly to the Modem, it reaches 200+ speeds, when connected to the ORBI, it dips below 100. Today is reading from 58 to 80 Mbps.
Please describe more about how speed is being measured:
- Using a Speed Test run on the PC when it is connected to the router or to the XB-7?
- The Cat6 cable connecting the PC to the Orbi is disconnected from the Orbi, the Orbi is disconnected from the modem, and the cable is connected to the modem?
- i.e. only one cable is involved in the test scenarios?
plemans suggested that it would be useful to determine which speed the modem and Orbi have negotiated.
(See Wikipedia: https://en.wikipedia.org/wiki/Autonegotiation ) This is a feature built into the physical Ethernet adapter hardware for the past 20+ years. If the modem/router have negotiated a speed of 100M/Full Duplex, then is is impossible to measure a speed as high as 100Mb/sec (because of Ethernet overhead).
The primary cause of the auto negotiation failing is "something about the cable" between the modem and router.
- Perhaps one of the tiny gold wires in one of the RJ45 jacks is bent or out of alignment.
- Perhaps one of the RJ45 plugs is not crimped entirely correctly.
- Perhaps the cable has been strained or crimped at some point.
- Perhaps one of the plugs is not seating correctly (the tiny 'snap thingy' is worn or loose).
The most obvious trouble-shooting step is to swap out the cable between modem and router with a new cable.
- chapotitoAspirant
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
