mbshaughnessy
Apr 18, 2022Aspirant
My Orbi Satellite issues
| Hardware Version | CBR750 |
| Orbi Firmware Version | V4.6.5.8_2.0.54 |
| CM Firmware Version | V1.01.08 |
I
The system is 5 months old, the last few weeks the satellite has been having issues. Dropping connections and after a week or so there are no active connections on the satellite. I power off, things are going good, then back to no connections. I have moved it to several locations in the house, now in a room where several devices are within 6 feet, same thing. Open to any suggestions
Hopefully with the changes and reducing the power some, should help.
What FW is loaded on the RBS?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
- mbshaughnessyAspirant
FW: I believe V4.6.5.14
1600 sqft townhouse, 2 story, 41 ft distance between the router and satellite, both on second floor almost clear line of sight. drywall construction (cheap California)
Two close neighbors
Currently set to Auto and 48 on 5ghz
Updated Coexistence and CTS, preamble was set to auto
Will reboot later, family finishing work. I appreciate the guidance
1600 sq ft maybe a bit small for the CBR and RBS...
Lets see how it works with the changes. You might turn down the transmit power on the CBR to 50%.
