eansys
May 07, 2026Aspirant
My RBR850 has an unstable guest network
My RBR850 has an unstable guest network. The firmware is V7.2.8.2. In addition to the router, I also have 3 satellites. The firmware updates automatically, however, I see version v.7.2.8.5 on the i...
KevinLiT
May 18, 2026NETGEAR Moderator
Hello eansys ,
Welcome to the NETGEAR Community!
I understand that you have been having issues with your RBR850 guest network stability. Stability issues may be linked to using a wireless band that is not compatible with your end user devices. To mitigate the stability issues on your guest network, change your guest network password encryption settings to WPA2-PSK [AES].
Best,
Kevin
NETGEAR Team
