larutan's avatar
larutan
Follower
Dec 07, 2021
MyQ 2.4G Garage to Orbi RBR750 (non-technical)
Like many folks I was having difficulty getting the MyQ garage door opener set up after upgrading to Orbi AX4200.  I understood that the problem was my phone was connecting via 5G to the network instead of 2.4G due to the Mesh.  I was not comfortable updating my router settings from a command line to seperate the 2.4G and 5G SSIDs.  I was very frustrated, when I remembered that 2.4G had much longer range the 5G.  So, I unplugged my satellites and covered my RBR750 with two metal stock pots.  This "artifical distance" due to interference degraded the signal in my garage to the point that I was out of 5G range and I connected via 2.4G.  Once on 2.4G, I was easily able to change the MyQ wifi settings in the phone app.  Voila.  Problem solved.
1 Reply
  • FURRYe38's avatar
    Also try turning down the power output of the RBRs wifi radios from 100% to 25% Under Advanced Tab/Advanced Settings/Wireless Settings as well to help with the distance vs connection with the mobile device.
    Enjoy.
