Pattersc
Jan 04, 2026Aspirant
NAT issues on Xbox
Trying to set up remote play on my Xbox series x and for the NAT it states that the Xbox “Can’t get a teredo IP address”. I’ve tried port forwarding, upnp, and a DMZ and nothing has changed it. Any s...
Jan 05, 2026Guru - Experienced User
Is IPv6 enabled on the CBR?
Check with the ISP for IPv6 configuration requirements.
Pattersc
Jan 05, 2026Aspirant
When I enable IPv6 it locks everything up like it’s not working at all
- FURRYe38Jan 05, 2026Guru - Experienced User
Check with the ISP to see which IPv6 configuration is needed. Usually DHCP or Auto Config, however check and see which one they prefer. Also try using custom IPv6 DNS like Cloudfare or Quad9.
- PatterscJan 05, 2026Aspirant
Each “tech” I’ve gotten with Xfinity has been clueless and blames everyone else. They may be right but just haven’t been a help. Unfortunately, other than Starlink, they are my only option
Was this working up to this point or just started happening?
