Pattersc
Jan 04, 2026Aspirant
NAT issues on Xbox
Trying to set up remote play on my Xbox series x and for the NAT it states that the Xbox “Can’t get a teredo IP address”. I’ve tried port forwarding, upnp, and a DMZ and nothing has changed it. Any s...
Jan 05, 2026Guru - Experienced User
Is IPv6 enabled on the CBR?
Check with the ISP for IPv6 configuration requirements.
FURRYe38 wrote:Is IPv6 enabled on the CBR?
FYI, teredo is used for ipv6 tunneling.
- FURRYe38Jan 05, 2026Guru - Experienced User
Yep.
Also FYI, IPv6 isn't really needed for XBOX. My ISP doesn't support IPv6 natively and have been using xbox for years with out it.
