Pattersc
Jan 04, 2026Aspirant
NAT issues on Xbox
Trying to set up remote play on my Xbox series x and for the NAT it states that the Xbox “Can’t get a teredo IP address”. I’ve tried port forwarding, upnp, and a DMZ and nothing has changed it. Any s...
Jan 05, 2026Guru - Experienced User
FURRYe38 wrote:Is IPv6 enabled on the CBR?
FYI, teredo is used for ipv6 tunneling.
Yep.
Also FYI, IPv6 isn't really needed for XBOX. My ISP doesn't support IPv6 natively and have been using xbox for years with out it.
