lostintransit
Nov 12, 2025Follower
Need help getting signal from house to barn
I have a RBR750 Router with 2 satellites inside my home. Everything works great. I recently built a barn about 190' away from my home, that I added a 3rd satellite in. The barn seems to be t...
CrimpOn
Nov 12, 2025Guru - Experienced User
Would have been great if when the electrical supply was installed to the barn an extra PVC conduit was laid for an Ethernet cable. (sigh. hindsight and all)
The most common solution for this situation is a "point to point wireless bridge". Amazon search will produce a range of products from $100 to $300.
It would be a good idea to spend a few minutes reading the user comments on some of the products. Notice how often "barn" comes up.
Generally speaking, one would be more likely to consider products from known companies, such as Ubiquiti, TP-Link, etc. and products with hundreds of reviews rather than just a few.
This solution appears to the equipment on each end to be an ordinary Ethernet connection.
These products are often rated in terms of kilometers, so 200 ft. is not a challenge. They may even be strong enough that the units can be mounted inside the house and the barn (if the walls are not metal). This avoids the bother of penetrating the exterior walls to run the PoE cables outside.
Netgear does not sell an outdoor rated satellite compatible with their WiFi6 or WiFi7 products.
Some people have used plastic "weatherproof enclosures" to place an indoor rated satellite outside. The main obstacles to this solution are the electrical connection and preventing overheating.
