Nakamichi
Jun 27, 2021Aspirant
Need help on upload speed ORbi Mesh R840
I have ATT giga fiber BGW 210 connected to ORbi RBR840 through IP bypass, ORbi in AP mode. While the download speeds on my iPhone 11 Pro Max are close to 800, the upload even just 1 ft away is 80 - 100. I have wired my laptop to ORbi Router and have seen 800 + both ways so ORbi receives great speeds from the ATT router but why is WiFi UPLOAD so poor or should I take this for granted? Are there any settings on the ORbi that could affect the UPLOAD even 1 ft away? Both the Router and 1 Satellite are on the latest firmware.
Any help or troubleshooting, appreciated.
Try tesing with a different wireless device...
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.- NakamichiAspirant
Thanks for replying. I have tried the same with my M1 IPad Pro but the same UPLOAD speed even from a foot away - 80-90 MBs. The download is 800 + but upload really sucks. The satellite is < 30 ft away from the router and is wired but the best upload speed has been about 100 or so less than a feet away from the router.
Try speed testing with the RBS turned off to ensure your devices are connecting at the RBR.
Check the connection rate between the RBR and your ISP modem as well.
Under Advanced Tab/Show stats button...
Might try a factory reset on the RBR as well...
