desean's avatar
desean
Netgear Orbi RBK852 Static Route not working
Model: RBR850 (main unit of RBK852)
Firmware: V3.2.18.1
I have another router (Xiaomi Mi AIoT Router AC2350) on 192.168.1.3 running another subnet under 192.168.2.x. (I do not want them to be on the same network, so nothing about bridge/AP mode).
I created a static route with destination 192.168.2.0 and gateway 192.168.1.3, but it does not work to route traffic (for example 192.168.2.1 or 192.168.2.214 is not accessible). Any idea what is wrong?
Static route screenshot: https://cldup.com/8nq5tWA4eu.png
DHCP screenshot: https://cldup.com/DkG06UKUIJ.png
  • Have you tried opening debug screen (192.168.1.1/debug.htm) click on "start capture" and after 10/15 seconds on "save debug file". The archive should contain a file called info.txt with routing table...
    Is your static route present?
    P.S. i think your metric should be 1 not 2 (but maybe i'm wrong)
    • desean's avatar
      desean
      Hi, thanks for pointing me to debug page, and I do see my static route in the output.
      ==========================route==============================
      Kernel IP routing table
      Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
      default         fnet1-f92-acces 0.0.0.0         UG    0      0        0 eth4
      10.0.1.0        *               255.255.255.0   U     0      0        0 br-guest
      143.158.81.0    *               255.255.255.0   U     0      0        0 eth4
      143.158.81.1    *               255.255.255.255 UH    0      0        0 eth4
      192.168.1.0     *               255.255.255.0   U     0      0        0 br-lan
      192.168.2.0     192.168.1.3     255.255.255.255 UGH   1      0        0 br-lan
      • kolella's avatar
        kolella
        Apprentice
        Netmask is 255.255.255.255 should be 255.255.255.0 (and metric i've seen that netgear wants 2)
        my 850 is in AP mode i've tried to add a static route 192.168.2.0/24:
        default         192.168.3.1     0.0.0.0         UG    0      0        0 br-lan
        192.168.2.0     *               255.255.255.0   U     0      0        0 br-guest
        192.168.2.0     192.168.3.27    255.255.255.0   UG    1      0        0 br-lan
        192.168.3.0     *               255.255.255.0   U     0      0        0 br-lan
        192.168.2.0/24 was overlapping with br-guest (added by orbi automatically) changed the static to 192.168.4.0/24 emd netmask is still correct
        192.168.4.0     192.168.3.27    255.255.255.0   UG    1      0        0 br-lan
