ArkAngel268
Nov 18, 2025Aspirant
NETGEAR Orbi RBSE960 AXE11000 constantly dropping WiFi connection
Good day, I currently have 1 router and 3 satellite in my home which is 2200sqft. I have it on auto channels I have owned the Orbi RBSE960 AXE11000 system since 2022 In 2023 all my WiFi devices...
Nov 18, 2025Guru - Experienced User
Does this happen with all RBS turned OFF?
How many devices in total is connected to the system?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
IS IPv6 enabled on the RBR?
What channels are you using on the RBR?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
For that size of home, the RBR would be enough, maybe ONE RBS out at 30 feet. 3 satellites is too much: https://youtu.be/UR0viMLISz4
Please turn OFF two RBS and test.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
I currently have my 963 series online now and all is good with two RBS. However my home is 5k sq feet.
- ArkAngel268Nov 22, 2025Aspirant
thank you for your reply i have tried turning off 2 of the mesh satelite and the kitchen is still a dead zone
can you offer me advice on placement with the 30 feet my house is not that big for it to have dead spots
hoping that anything can improve my ongoing issues having a dead spot in my house has become extremely frustating.
- KevinLiTNov 24, 2025NETGEAR Moderator
Hello ArkAngel268 ,
Thank you for your response!
Absolutely, please navigate to the links provided below for placement recommendations for your Orbi Mesh system:
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-router-and-satellitePlease note that if you are only able to have the router on the edge of the network, you may have to set your network up for a daisy chain topology if there are compatibility issues.
Please navigate to the link below for additional information about daisy chain topology:
https://www.downloads.netgear.com/files/GDC/RBKE963/RBRE960_RBSE960_UM_EN.pdf (Page 19)Best,
Kevin
Community Team
- FURRYe38Dec 02, 2025Guru - Experienced User
Any progress on this?
Please post a drawing or diagrame of the floor lay out of your home and mark where you have the RBR and had the RBS placed so we can get a better idea of the situation.
