drdre892001
Dec 11, 2024Aspirant
Netgear RBKE962 satellite keeps disconnecting intermittently
I have the RBKE962 satellite positioned in my lounge room, which is connected wirelessly to my TV, streaming box and soundbar all in the same room via 5ghz. The main router is down the hallway. ...
drdre892001
Dec 12, 2024Aspirant
The distance between the router and satellite is just over 30 feet. (10 meters).
House is not that big. Not sure exact square meters.
I noticed it when my YouTube on my LG TV started buffering and getting slow connection. Wondering why. I was checking out the Orbi app and seeing what was connected to the satellite.
Then I saw that my lounge devices were connecting to the main router, and not the satellite.
Once again, when I power cycle my lounge devices they immediately connect to the Satellite and have a super fast connection. But I noticed after a few days something happens and then my devices connect to the main router.
Something is causing the Satellite to disconnect. And I have actually noticed it sometime in the morning where I would see the Satellite flash with a blue light , then eventually the blue light would turn off.
My RBKE962 is fairly new. Only had it for about a month.
Dec 12, 2024Guru - Experienced User
Might bring the RBS in just a bit closer to the RBR and see?
FYI, v.31 FW hasn't been good for users, you might downgrade the system to .21 on the RBS first then RBR lastly and then factory reset and setup from scratch and check for this issue. v.21 is most stable version to date.
- drdre892001Dec 12, 2024AspirantOk. How can I downgrade to .21 ? …
Or would setting up WIRED backhaul fix it.
Lucky I saw the satellite flashing blue early one morning. That confirms to me it’s disconnecting and reconnecting.- FURRYe38Dec 12, 2024Guru - Experienced User
Downgrade using this process in this linked PDF:
RBS first, then RBR lastly.
Factory reset using this PDF process afterwards:
Ok I've now downgraded to FW .21 and also done a factory reset on both RBR and RBS. Will see if this fixes the issue. thanks.
- drdre892001Dec 12, 2024AspirantOh just saw this post. Looks like these are the problems I’m experiencing with FW.31 !
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Major-Firmware-7-2-6-31-issues/m-p/2380396
