solarisfps
Jan 23, 2022Aspirant
Netgear RBR750 x2 backhaul/daisy still connecting via 5g
I live in a 3 bedroom house and i have the Orbi RBR 750 router and 2x satellite i have a cable running from my bedroom downstairs to the kids room to create a backhaul. Then there is a satellite in the living room which is connected via ethernet to the kids room so its daisy chain.
I updated to firmware V4.6.7.5_2.1.7 to see if this will fix the issue and no luck as of yet it still shows both satellites connected to the route via 5g and i cannot get it to prefer the wired connection. I have turned down the wireless strength to 25% for 5g and no luck doing this either.
How can i force the satellites to connect via ethernet to the router instead of wireless, it defeats the entire purpose of what i was trying to achieve.
is there any switches in between? is it running from wall plates?
Have you taken a known good 6ft cable and just put the satellite next to the router and hardwired it in (to test if the backhaul connects)?
- solarisfpsAspirantI ran a cat 6 cable from upstairs to the kids room and terminated the ends myself. I used a rj45 tester which passed the test.
There are no switches in between the router and the satellites.
The only thing I can think of doing is reterminating the 1st connector I did as maybe there is any issue not sure.- plemansGuru - Experienced User
Just try moving the satellite first for testing. If it works, you know its the cable run and you can try replacing the ends. Most people have a spare 6ft cat 5e (or better) cable sitting around.
Its always good to test if its the cable or the satellite.
