Rodxmas
Jan 13, 2026Aspirant
Netgear RBR850 requires frequent resets to correct connected without internet.
My setup: Router: Netgear Orbi RBR850 AX6000 Firmware: V7.2.8.5_5.1.21 IPv6: Disabled Security: Using Netgear Armor + Netgear Parental Controls Satellites: Two RBS850 units Home layout: 186...
Jan 13, 2026Guru - Experienced User
Does the front LED on the RBR turn PINK or blink WHITE when this happens?
When did this start happening?
How was the FW uppdated on the system? Auto Update or manually?
Using ISP detected DNS or custom DNS?
Does disabling Armor or SPC change this behavior?
Try putting a 1Gb non managed switch in between the ONT and RBR iwth only these two being connected to this switch?
