Rodxmas
Jan 13, 2026Aspirant
Netgear RBR850 requires frequent resets to correct connected without internet.
My setup: Router: Netgear Orbi RBR850 AX6000 Firmware: V7.2.8.5_5.1.21 IPv6: Disabled Security: Using Netgear Armor + Netgear Parental Controls Satellites: Two RBS850 units Home layout: 186...
Rodxmas
The LED stays off when it happens.
About 6 weeks ago.
The FW was initially on the auto update. Today during the reset it was manual.
Using ISP dynamic DNS address.
I have just disabled armor and the parental controls today.
Jan 13, 2026Guru - Experienced User
Ok so you manually re-applied the same version of FW on the RBS then RBR?
Please try custom DNS like Cloudfare or Quad Nine as well.
