norfolkgeorge
Jul 12, 2023Tutor
NETGEAR RBS750 connection to 2 satellites
This router and two satellites has been in use for just over a year. However, it is now not working properly. I can connect both satellites by ethernet but neither by wireless even when within a coup...
norfolkgeorge
Jul 12, 2023Tutor
Yes, I tried factory reset to no effect.
For router:
| Hardware Version | RBR750 |
| Firmware Version | V4.6.9.11_2.3.5 |
| GUI Language Version | V3.0.1.51_2.1.30.3 |
| Operation Mode | AP |
For Satellites: Hardware Version: RBS750 and Firmware Version: V4.6.3.16
Jul 12, 2023Guru - Experienced User
I'd upgrade the firmware to the newer one for both the router and the satellites. Make sure to upgrade the satellites first, then the router. Then give them a couple days and see if anything's connecting to the satellites.
- norfolkgeorgeJul 12, 2023Tutor
Will certainly try -although when I did factory reset, I was told I was told firmware was up to date!
- plemansJul 12, 2023Guru - Experienced User
it doesn't always report accurately.
Orbi RBR750 | WiFi System | NETGEAR Support
I prefer the manual update method.
