Wiltronics's avatar
Wiltronics
Network management App and Web user interface
Recently bought the RBR750 — Orbi WiFi 6 System AX4200 with 2 RBS750.
Router setup in AP mode and in average 8 devices connected using 1Gbps Fiber Internet connection. Experience intermittent Network management App and Web user interface isn't able to access the system anymore. Only resolution is to reboot the RBR750 which regains again access to the network mngt tool. Keen to learn anyone experience this issue and possible resolutions.
  • Last week Saturday updated the RBK753 to Firmware Version, V3.2.16.6_1.4.4
    since then both the App and Web GUI working perfectly fine. Through the week extensively testing with downloads and upload and testing the App and GUI no problems detected.
    • Wiltronics's avatar
      Wiltronics
      Netgear support; any findings and updates on this topic?
      • FURRYe38's avatar
        What version of FW are you using? v32 is most current.
        Are you using a Dynamic IP address or a Static IP address configuration on the RBR when in AP mode?
        What is the mfr and model # of the main host router the RBR is connected to in AP mode?
