Feb 22, 2025Guru - Experienced User
New - Orbi RBR/RBS 850/860 and 960 series Firmware Version 7.2.7.15 Released
Enhancements: 02/21/2025
Added Router Protection support.
Bug Fixes:
Fixed a WiFi connection stability issue.
Fixed various bugs.
Security Fixes:
This firmware addresses securit...
spewak
Feb 23, 2025Luminary
Thanks Furry!
Eriksen76
Feb 23, 2025Apprentice
Thanks a lot. I will wait a few days before updating đŹ
- Retired_MemberFeb 23, 2025
It will be interesting to see if this firmware fixes the issue I discovered in regards to the 2.4GHz band, knocking out both the 5GHz and 6GHz bands.
See below posts for more info.
- F_VFeb 23, 2025Luminary
I updated my 960 right away yesterday and it's been rock solid. Course, it was rock solid before, so your mileage may vary. Oh, actually one issue, my Android Orbi app (verified updated) will no longer connect to the RBR960. I just get a white screen when I start it up. Uninstalled and reinstalled, same issue. Perhaps it's an app issue and not related to the firmware update, but it certainly worked before the new firmware.
- FURRYe38Feb 23, 2025Guru - Experienced User
How was your system updated? Via AutoUpdate, Manually or Update ALL?
Did you update and continue to use the system after it rebooted or was there a power cycle of the system OFF for 1 minute then back ON or did you do a factory reset and setup from scratch?
Is your RBS wirelessly connected or ethernet connected?
