Feb 22, 2025Guru - Experienced User
New - Orbi RBR/RBS 850/860 and 960 series Firmware Version 7.2.7.15 Released
Enhancements: 02/21/2025
Added Router Protection support.
Bug Fixes:
Fixed a WiFi connection stability issue.
Fixed various bugs.
Security Fixes:
This firmware addresses securit...
horustx
Apr 22, 2025Guide
You neglected to mention that Version 7.2.7.15 breaks IPv6 for RBR850 and RBS850.
I tried to reach out to customer support (a few weeks back), but they wanted me to pay to report a bug Netgear introduced through this firmware update.
In short: you reboot the router, and IPv6 works for a moment (a minute or two) then stops working. Resetting the router does not work. Other routers with the same cable modem work fine with IPv6.
Many reported the same issue on multiple forums.
