FURRYe38's avatar
New RBK852/853 Firmware v3.2.9.2 Release
New Features and Enhancements:
  • Supports connecting two satellites to the Orbi network
Bug Fixes:
  • The Orbi app was not able to show the guest client’s link rate if the Orbi was operating in AP mode
Known Issues:
  • Unable to fix the 2.4G in HT40 only mode issue. This will be fixed in next release.
  • After installation, changing the Internet connection type from DHCP to Static IP requires a reboot to take effect
Download Link:
RBR850 - http://www.downloads.netgear.com/files/GDC/RBK852/RBR850-V3.2.9.2_1.2.4.zip
RBS850 - http://www.downloads.netgear.com/files/GDC/RBK852/RBS850-V3.2.9.2_1.2.4.zip
Be sure to update the RBS first, then RBR lastly.
Let us know how it works for you...
    • Chuck_M's avatar
      Chuck_M
      Mentor
      I have found one odd piece of behavior with the new update.
      On my system I have 1 x RBR850, 1 x RBS850 and 2 x RBS50s.
      The RBS50s are hard wired.  The RBS850 is RF Backhauled.
      Since the update to this version, the RBS850 reports itself as hard wired even though it is not.  It reports this in both the Web GUI as well as the App.
      I have rebooted with no change to effect and checked it again after 12 hours -- still the same.
      Anyone else see this behavior?
      • FURRYe38's avatar
        I'll check mine again, however list time I looked both my RBS reported wirelessly connected since both of mine are wirelessly connected.
  • Please create a way to enable Orbi app remote enable from orbilogin.com.
    Product registered but fails with enabling remote management from the app for the app.
