SydneyLad
Feb 12, 2026Aspirant
New RBS750 (satellite) ... can't check/flash the firmware
Hi all, Having some challenges with a new RBS750 satellite to connect to a pre-existing setup of RBR750 and another RBS750. The latter 2 are on V7.2.6.31. I do not know what the new satellite...
SydneyLad
hey FURRYe38 - appreciate the response so quickly
I believe it is new (ebay - as its an older model so you never know .. it looks new).
I tried the above however with the desktop PC wirelessly connected to the network. I have a USB / Ethernet converter arriving today so will try again but with the PC wired (PC only has 1 ethernet port currently). Wish me luck.
IP address is 192.168.1.26 in my first solution attempt. Respective 192.168.10.250 & 192.168.1.250 with 2.1 and 2.2 solution attempts above.
Thank you for the
https://www.reddit.com/r/orbi/comments/kjslnh/how_to_completely_reset_an_orbi/ 30-30-30 reset (link included for other readers). I will try the wired solution first.
