SydneyLad
Feb 12, 2026Aspirant
New RBS750 (satellite) ... can't check/flash the firmware
Hi all, Having some challenges with a new RBS750 satellite to connect to a pre-existing setup of RBR750 and another RBS750. The latter 2 are on V7.2.6.31. I do not know what the new satellite...
SydneyLad
I will add .. with Solution 1 I tried ... having the PC wired (and also wireless) on the network with the new RBS750 wired directly into the RBR750 made no difference - I was unable to open the satellite interface via 192.168.1.26
Feb 12, 2026Guru - Experienced User
Ethernet PC needs to be directly connected to the back of the RBS. RBS needs to not be connected to anything. Just the Ethernet PC and the RBS connection in between them.
- SydneyLadFeb 12, 2026Aspirant
And I've also confirmed that the router is not connected to the satellite (its not showing at all in the webui for the router under attached devices)
(and the satellite is a solid white colour)
1. Hmmm… can't reach this page [when opening in Edge]
192.168.10.250 took too long to respond
2.
C:\Users\me>ping 192.168.10.250
Pinging 192.168.10.250 with 32 bytes of data
Reply from 100.99.128.1: Destination net unreachable.
Ping statistics for 192.168.10.250:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
3.
C:\Users\me>ipconfig
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : XXXX::920f:fb3b:3d6c:d528%57
IPv4 Address. . . . . . . . . . . : 192.168.10.49
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
