Mastra11
Jul 13, 2025Apprentice
Nintendo Switch 2 and Orbi 753 WiFi Information
Good morning, I have an orbi 753 system and a Nintendo Switch 2 that is correctly connected to 5GHz WiFi. The orbi router is almost next to the Nintendo Switch 2. However, I noticed something: when I...
Jul 13, 2025Guru - Experienced User
Can do a search in the forums to see if others have posted about it. May not have since the switch 2 is fairly new product.
Something to ask Nintendo support about as well.
What FW version is loaded on the 750 series?
Does this happen if you turn OFF all the RBS and just connect to the RBR only?
Try setting a IP address reservation on the RBR for the game device.
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
Mastra11
Hi, the console is connected to the WiFi directly to the RBR in 5Ghz, I have not turned off the satellites and on the RBR and satellites there is version 4.6.9.11_2.3.5 which works well.
- FURRYe38Jul 13, 2025Guru - Experienced User
You are behind on FW. Could update FW and see.
Might try v.21 version first...
https://community.netgear.com/kb/en-orbi-knowledge-sharing/procedure-to-manually-firmware-update-orbi-and-nighthawk-mesh-systems-/2456254
- Mastra11Jul 13, 2025Apprentice
Hi, I decided not to update because the system is working fine. Then when I try to search for a firmware update on the router's page, it says there are no updates and it's already up to date. Do I need to install them manually now?
- FURRYe38Jul 14, 2025Guru - Experienced User
You can find current and previous versions of FW here: https://www.netgear.com/support/product/rbk752/#download
Previous link references how to apply FW manually
