CreeksongOrbi
Mar 15, 2022Aspirant
No internet through Orbi when modem set to bridge mode.
Modem: Teltonika RUTX11 (AT&T) Orbi Mesh WiFi 6 System - AX4200 (RBK752) Internet accessible through modem, and through Orbi when modem not set to bridge. But this configuration produces notic...
CrimpOn
Mar 15, 2022Guru - Experienced User
I cannot find an explanation of how Bridge mode is different from Passthrough mode.
https://wiki.teltonika-networks.com/view/RUTX11_WAN
- CreeksongOrbiMar 16, 2022Aspirant
ISP (AT&T Reseller) says "Passthrough" requires full factory reset to undo (meaning physical access to the modem, which is mounted at 3-story peak); "Bridge" can be undone via ethernet access to modem.
I've not been able to confirm that in any Teltonika documentation -- nor have I found any other explanation of the difference.
- FURRYe38Mar 16, 2022Guru - Experienced User
I would contact your ISP and have them help you with this. There maybe some user account or PPPoE account information needed on the RBR to make it work when the ISP modem is in bridge mode.
Already contacted ISP -- should work as configured. I'm stumped.
Only other option I see is to put Orbi itself into bridge mode; loss of some Orbi functionality, but it might improve performance.
