sean60791
Feb 19, 2026Follower
No sure if my ORBI RBR750 is broken
I have an ORBI RBR750 system for about 3 years now. A tree fell during an ice storm and knocked out my FIOS internet. I got on AT&T cellular internet for a few days until FIOS service returned.
I put the ORBI on the AT&T router and it ran fine. Once FIOS service returned, I put the ORBI back on FIOS. A few days later my ORBI units no longer work. I have done a factory reset on ORBI units, they no longer work on AT&T or FIOS. The lights are static white.
Any ideas?
1 Reply
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure your using a good quality LAN cable between the modem and router. CAT6 UTP is recommended.
Check with ISP for FIOS configurations that maybe needed on the RBR.
Try using custom DNS for IPv6 like cloudfare or quad9
Disable IPv6 on the RBR.
