pshah3334
Oct 14, 2021Tutor
Not able to have multiple SSID on Orbi
Submitting this topic again in correct forum (instead of general forum). Router - Orbi RBR753 (AX4200) Firmware version - V4.6.5.14 Main OS for my devices - Windows 2 issues after upgrading...
pshah3334
Oct 14, 2021Tutor
Thank you for your quick response on my questions.
Additional information you asked for - ATT Uverse Modem - 5268AC FXN
For #1 - Not sure when I spent $400 for router why can't have this simple feature (to support devices both based on WPA2 and WPA3 protocols). I hope NetGear team works on this as priority basis as many people raised this concern.
For #2 - I already used USB adapter (and not what comes with my laptop) and same behavior. When I ran ipconfig command it is not using same gateway as I am seeing on other devices. According Netgear support team for some reason it uses modem's gateway for some reason. But they do not know why? Also, this issue started after changing my router to use WiFi6 capabilities.
Oct 14, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would post about asking NG getting Mixed WPA modes on Orbi AX systems here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Or open a support ticket and let NG know about this:
