Nov 19, 2025Guru - Experienced User
NOTICE: New - RBK750/850/860 Firmware Version 7.2.8.2 Released
Get it here:
Orbi Firmware Releases | NETGEAR Communities
No mention of IPv6 issues being fixed.
Please try and post any findings or results.
Good Luck.
Garwoofoo
Nov 20, 2025Apprentice
Some more details in case anybody has any ideas.
The satellite works fine when connected via wireless backhaul (as it always has).
As soon as I connect it via Ethernet cable, any devices that try to connect to it immediately drop off the network. I can't get any devices to stay connected to that satellite at all.
Anything that is connected to the satellite before I connect the Ethernet cable STAYS connected and continues to work. Which makes me think that the problem is perhaps with DNS allocation or similar.
This setup (one wired, one wireless satellite) worked fine in every previous Orbi firmware version and nothing else about my setup has changed apart from this firmware upgrade.
I didn't do a factory reset before upgrading from 7.2.7.15 (and, frankly, don't really want to go through the hassle) but I followed good upgrade advice (satellites first, then router, followed by a full power cycle) and that has always worked for me in the past.
Nov 20, 2025Guru - Experienced User
When the RBS are ethernet connected, are they connected directly behind the RBR or is there any kind of LAN switch in between then? If there is a LAN switch brand and model please.
