  • plemans's avatar
    what actual device do you have? (ax4200 is a speed)
    there's differences.
    1. its usually 32 devices per band
    2. most support up to a total of 250 devices
    3. the concurrent usage is usually that 50-60 devices. But if half of them are high bandwidth devices, then its going to be a little different.
    so a lot depends on what you're actually doing and if you're doing it at the same time.
    • Notwoke's avatar
      Notwoke
      Orbi AC4200 2 pack, RBK 752. I have 4 Roku sticks, 4 wifi cameras, 2 tablets, 2 phones 2 PCs, alarm, 3 echo devices and other smart home things, bulbs, plugs, switches, garage door opener. No gaming. Only 2 of us in the home so high bandwidth devices like the Roku wouldn't be on at the same time. My concern is 40 the limit or 40 high bandwidth at once?
