Mastra11
Jul 30, 2026Apprentice
Numerous DHCP requests Tesla Powerwall 3
Good morning, I have a Netgear Orbi 753 router and two satellites connected to Wireless Backhaul, satellite one connected to the router and satellite two connected to satellite one. I have a Tesla Po...
Mastra11
Hi, thanks for your reply. I can't activate the IoT network, and I can't move the satellites closer together because they're placed in specific spots to cover the house. Why does Orbi sometimes use 20MHz and sometimes 40MHz in 2.4GHz? Thanks.
Jul 30, 2026Guru - Experienced User
Mastra11 wrote:I can't activate the IoT network
Why is that?
Mastra11 wrote:Why does Orbi sometimes use 20MHz and sometimes 40MHz in 2.4GHz?
It's a "good neighbor" policy required by the WiFi Alliance (that certifies wifi products). If the router detects another overlapping access point nearby, both systems scale back to 20 MHz.
If you log into the web admin ui, then you can select the "Advanced Tab", and then "Advanced Setup". The Wireless Settings menu in that section should include a checkbox for "enable 20/40 MHz coexistence". You can turn that off if you want to disable that policy.
To be clear, the powerwall (or other wifi clients) can still choose to connect at 20 MHz if you do this. The powerwall doesn't use much bandwidth, and the narrower channel can reduce interference and increase range.
FWIW, I doubt that is the problem. It is more likely that the 5 Ghz band isn't delivering a solid connection at the powerwall. That would result in the powerwall switching back and forth.
If the powerwall monitoring is working ok, then you could just leave well enough alone.
- Mastra11Jul 30, 2026Apprentice
Yes, I always see the Powerwall online and I always see the monitoring
