Mastra11
Jul 30, 2026Apprentice
Numerous DHCP requests Tesla Powerwall 3
Good morning, I have a Netgear Orbi 753 router and two satellites connected to Wireless Backhaul, satellite one connected to the router and satellite two connected to satellite one. I have a Tesla Po...
Mastra11
I use channels 11 for 2.4GHz and 44 for 5GHz, which I set manually. I don't know the exact distance between the satellites; they're just one on each floor. The Powerwall is outside on the floor where the Orbi router is located. I haven't updated the firmware because it's working fine now, and I'm afraid it might cause problems.
Jul 30, 2026Guru - Experienced User
Size of home in sq ft please.
Distance could be at play here. If RBR and RBS are too close, then wifi signal overlap in between the RBR and RBS maybe causing fluctuations in signal thus causing the device to ping pong around and not able to stay locked on to one signal.
Might try turning OFF one of the RBS and see if this helps keep the device connected to one or the other signals...
