xaustie
May 17, 2025Guide
Odd RBR750 Netgear log behavior - a feature?
I recently upgraded my RBK753S setup from the really old V4.6.8.2_2.1.9 to V7.2.7.15_5.1.16. The upgrade went flawlessly. Everything is working just fine. There is only one thing that is different no...
May 17, 2025Guru - Experienced User
Looks like something from Singapore is hitting that device:
https://www.whois.com/whois/38.182.139.10
What happens if you turn that device OFF or remove the PF Config for that device.
