xaustie
May 17, 2025Guide
Odd RBR750 Netgear log behavior - a feature?
I recently upgraded my RBK753S setup from the really old V4.6.8.2_2.1.9 to V7.2.7.15_5.1.16. The upgrade went flawlessly. Everything is working just fine. There is only one thing that is different no...
xaustie
May 18, 2025Guide
Turning device off may no difference. Removing the PF Config for the device resulted in no more entries in the log. I have re-enabled the device. My only guess at what is happening is that the logging when I had the old V4.6.8.2 was not a thorough as it is now. I consider this issue closed.
