hnz980's avatar
hnz980
Tutor
Jul 26, 2021
Orbi - RBR850 -WAN Port speed problems to Arris S33 - Surfboard DOCSIS 3.1 Cable Modem
Hello,
My Oribi Wifi 6 router is connecting at 100 mbps speeds to my Arris S33 DOCSIS 3.1 Cable Modem.
I am using the Cat 5E cables that were supplied.
My provider is Xfinity/Comcast and I have had GigE service for a while.
I recently upgraded from the Arris SB8200 to the newes version S33.
I had the provider trobleshoot the connection everthing checked out with the modem. I had a tech from Comcast come out and test the Cable speed and it checked out at GigE. I contacted Arris support and the Cable Modem checked out.
They mentioned to contact Netgear to find out why I am getting 100 mbps WAN speed.
Hardware VersionRBR850
Firmware VersionV3.2.18.1_1.4.14
GUI Language VersionV3.0.0.51_2.1.30.3
Operation ModeRouter
  • plemans's avatar
    not the tech but when you connect a pc/laptop to the S33, what speeds do you get?
    Have you tried changing to a cat 6 or great cable?
    What device are you testing wan speeds on?
    • hnz980's avatar
      hnz980
      Tutor
      I have not tried cat 6 cable. I will give that a go.
      When I do a hard wire directly to the S33 from my mac m1 with the Netgear supplied gig 5e. I get gigE speeds.
      • plemans's avatar
        Some cat 5e (cheaper ones) have been sketchy at best. I've had them with gig speeds for certain devices and not for others.
        Its usually why I'd recommend trying a different cable first.
        Also, look at the port on the router. Maybe a pin is bent or dirty causing it to limit to only 10/100mbps connections links
