physast's avatar
physast
Guide
Oct 03, 2021
Orbi + August lock (WiFi) = disconnect/reconnects
It was suggested that I post about this problem in this forum.
I have a CBR750 with one satelite mesh system on a 1GB cable internet. I have about 20 devices connected. My issue is that my august smart locks (wifi versions) keep disconnecting and reconnecting. This happens many times a day and sometimes upto 15 times a day. I think this is also causing the battery life of the smart lock to drain faster.
I am noticing these disconnect/reconnects because the Augus app sends them to me as an alert. I have not noticed them on other smart devices, but have not looked to see if those notifications are turned on for other smart devices.
My current firmware is: V4.6.3.6_2.0.48
Any ideas?
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, IPv6
    Set 20/40Mhz Coexistence to 40Mhz only. Set CTS values to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    IF these are the only devices having problems like this, I would make contact the the Mfr of these devices for help and support information as well.
    • physast's avatar
      physast
      Guide
      FURRYe38 Thank you for replying and these suggestions.
      • House is 1600 sqft
      • Feet between router and satelite is about 25 feet (plaster board walls, older house)
      • 2.4Ghz is on channel 6 and 5Ghz is set to 48
      • Many Wifi neighbors, about 7
      Armor is disabled, or not on because I don't have a subscription. I have not tried disabling IPv6 yet but will and report back. Will also try the other settings as well.
      I am also seeing disconnects now on other smart devices, Ring alarm being one and my VOIP phone.
      Sometimes when I log into the orber app I notice that some devices are not connected, but I would think they should be. For instance the August locks, Ring doorbell and some smart lights. Should they all always show connected? Is it normal to see some devices not connected?
      • FURRYe38's avatar
        What happens if you move the RBS out a bit farther? Say 35 feet?
        Try setting CTS to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings.
