ARL59
Oct 13, 2020Follower
Orbi 750 slow
I installed a 750 router with 2 satellites to an Xfinity gateway modem. My speeds from the gateway to the router are always fast but they are irregular and sometimes slow from different devices throughout the house. One of the two satellites is at the edge of the range and provides very slow speeds and unimpressive range. We run17 devices, including iphones, pads, laptops, and thermostats.
any suggestions on how to improve speeds, particularly on improving router to satellite speed? Can I connect the router to the satellites using powerline adapters?
Please post over in the Orbi AX forum for AX Model Orbi:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you. - MstrbigMaster
ARL59 wrote:I installed a 750 router with 2 satellites to an Xfinity gateway modem. My speeds from the gateway to the router are always fast but they are irregular and sometimes slow from different devices throughout the house. One of the two satellites is at the edge of the range and provides very slow speeds and unimpressive range. We run17 devices, including iphones, pads, laptops, and thermostats.
Regarding speed you would have to move the satellites closer to the router. Check your WIFI channel to make sure there is not a lot of traffic on it, and if so, change it to a cleaner channel.
Disable Circle, Armor and uncheck 20/40Mhz Coexistence, Enable WMM
You should be able to use Powerline Adapters. Just make sure you get the pass-through type with a plug socket built-in.
If your modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
