MissyBenita's avatar
Jan 16, 2022
Orbi 750 Tri-band mesh wi-fi 6 system - Set-up advice & Connection issue
Hello, I'm trying to reconfigure my existing Orbi system (CBR750 & 2 satellites) to add on a RBR750 (router) & 2 more satellites.  The second set was a Costco bundle & included the router.  My previ...
  • MissyBenita's avatar
    MissyBenita
    Jan 22, 2022
    Well I certainly messed up. In my confusion of settings, working with online support, etc., I realized that I had changed the WPA setting from 2 to 3. While trying to navigate the rabbit holes of figuring out the problem, I switched it back to 2. Got the tv back online & the Amazon Echo.
    Thank you for your initial response.
    I wish there was a concise & understable resource where the uninformed could navigate the pitfalls. I'm sure there is - I just have to find it.
