MissyBenita
Jan 17, 2022Tutor
Orbi 750 Tri-band mesh wi-fi 6 system - Set-up advice & Connection issue
Hello, I'm trying to reconfigure my existing Orbi system (CBR750 & 2 satellites) to add on a RBR750 (router) & 2 more satellites. The second set was a Costco bundle & included the router. My previ...
- Jan 23, 2022
Well I certainly messed up. In my confusion of settings, working with online support, etc., I realized that I had changed the WPA setting from 2 to 3. While trying to navigate the rabbit holes of figuring out the problem, I switched it back to 2. Got the tv back online & the Amazon Echo.
Thank you for your initial response.
I wish there was a concise & understable resource where the uninformed could navigate the pitfalls. I'm sure there is - I just have to find it.
MissyBenita
Jan 22, 2022Tutor
Oh, just to be clear - what I have is the CBR 750 as my main device, not the 40.
MissyBenita
Jan 23, 2022Tutor
- FURRYe38Jan 24, 2022Guru - Experienced User
FYI:
https://www.diffen.com/difference/WPA2_vs_WPA3
Were hoping NG will implement a Mixed Mode WPA2 and WPA3 option on there Orbi AX systems. They had it early one however there were problems found with mixed mode so it was removed. I believe they have been fixed so were hoping in future FW updates, NG will add it back in for compatibility across older and newer devices.
