Spoongooner's avatar
Jul 12, 2021
Orbi 752 753 Ax4200 DNS errors finally fixed, 404 errors, Page can not be displayed errors
For the last year all the new Orbis sytems I installed had major issues with DNS..Page cant be displayed..404 errors they worked mostly fine on COX, but on smaller point to point providers,, I was g...
  • FURRYe38's avatar
    Jul 14, 2021
    Please mark your thread as solved so others will know.
    Enjoy.
    they worked mostly fine on COX, but on smaller point to point providers,, I was getting lots of DUAL NAT issues,,and had to run then in access point mode behind a REAL router that actually worked...  ( will think long and hard before I sell another Netgear Product to anybody..)
    i just updated the firmware on the 752,   or 753 from Costco...  AX4200.. with firmware V4.6.3.7_2.0.49
    and they finally work
    you have to manually download the update from netgear support.
    and manually install to each satellite one at a time...  then do router last..
    thank you Netgear for finally fixing this mess...  I sold over 100 Orbi systems before this was a known issue and have been stuck for the last year doing patches and buying a 2nd non NETGEAR router to put in front of the ORBI's.
    I work in multi million dollar homes, that often needed 4,5,6 or more satellites..
    so we are talking about 1,000 invested per client i set up...  only to find out after return policy expires.. that they have a major bug with DNS timing out...
    I would have swapped them out for another brand.. but havent found anything much better..
    Ubiquity is always out of stock,, most store brands where horrible with MESH.. I think the Orbis have the best radios and mesh .. but had this horrible BUG for over 1 year.. SHAME on NETGEAR support for wasting all my time trying to fix my clients sytems because you release BUGGY firmware...
    Hopefully the update fixes your Orbi to... if not I had really good luck putting Orbi in AP MODE and using a real router from anyone other than NETGEAR
    you can find the firmware updates here.. they are to NEW for Orbi to auto install... you need to manually install them
    https://www.netgear.com/support/product/RBK752.aspx#download
