vmahadevan77
Oct 14, 2024Aspirant
Orbi 760 and Vodafone FTTP in the UK
Hi, I've just installed my new Orbi 760 and Satellite systems connecting to my Vodafone FTTP (gigabit fibre) My FTTP box on the wall connects to my Orbi main modem/router unit via ethernet an...
Oct 14, 2024Guru - Experienced User
You put what you were getting, but what are you getting now?
vmahadevan77
Oops. Apologies, forgot to mention speeds.
I am now getting with Orbi main and 3 satellites(2 hard wired and 1 via mesh) Max upload speed of 100 mbps and 70 mbps upload.
Spoke to tech support and was pretty much a waste of time.
She asked me to set the primary and secondary dns to 8.8.8.8 and 8.8.4.4
Any other tips?
- plemansOct 14, 2024Guru - Experienced User
Check to see if you're connected at multigig, gigabit, or 100mbps connection
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
maxing out at 100mbps makes me suspicious of the connection
- CrimpOnOct 14, 2024Guru - Experienced User
A speed of "almost 100Mbps" is often a clue that the router has auto-negotiated the Ethernet link at 100M/Full Duplex.
Can you check the Orbi web interface, Advanced Tab home page. Click the blue box "Show Statistics" to see what is listed for the WAN port?
If it reads 100M/Full, it might be a good idea to try a different Ethernet cable for the WAN port to the fiber box.
