HomeUserguy's avatar
HomeUserguy
orbi 850 dropping
I have on the latest firmeware and my wifi drops multiple times per day.  I know its not a device as my alart drops to cell, my phone drops, and PCs loose connection. I cant find anything in the logs saying that status. based on the wifi singal going down on a PC it would not appear to be the provider.  It typically drops for about 30 sec -1min and comes back.
Are there any know issues with the V4.6.3.16_2.0.51 firmware and better logs?
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try disabling AX mode on the RBR
    Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    Has a full reset and setup from scratch been performed?
    • striker69's avatar
      striker69
      Star
      I Would Try Running In The AP Mode. I Had A Similar Problem.
      • FURRYe38's avatar
        Would be kind of hard to run AP mode if the OP doesn't have host router in front of the RBR.
