David9
Aug 28, 2026Aspirant
Orbi 850 running V7.2.8.5_5.1.21 dhcp issues
Hi I recently switched my Orbi 850 back to router mode from AP mode as I have a new ISP. What i've found within a day is that the dhcp function on the Orbi 850 (+1 satellite) running V7.2.8.5_5.1...
Aug 30, 2026Guru - Experienced User
What brand and model# is the ISP modem that the RBR is connected too?
CAT# LAN cable used in between the modem and RBR?
What IP address pool string are you using on the RBR? Default 192.168.1.1?
Might try using a different DHCP IP address pool range. .100 to .200. I do.
Make sure all wifi adatper drivers are up to date for PCs that have these adapters.
Make use of the separate IoT network for IoT devices
Use manual channels 1 and 40 or 11 and 48.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
I've used this same FW version on my 960 series Orbi, same code base, bit different WIFI features, saw zero issues with DHCP and devices connected. I know my 850 series would work just as good.
- David9Aug 30, 2026Aspirant
How many device are on your network?
