SonicGT's avatar
SonicGT
Orbi 860 can’t connect to my western digital nas
I had an old Orbi system and decided to upgrade. For the most part everything worked fine. But while it sees my NAS which is connected to an Ethernet port on the router I can’t connect to it. I can’t ping the ip or get to it at all. Under the upnp page it shows it in the routing but I can’t access it in any way
  • CrimpOn's avatar
    CrimpOn
    Trying to connect to the NAS
    • From a device on the same LAN, or
    • From a remote device?
    • SonicGT's avatar
      SonicGT
      Sorry forgot to get that specific
      Local network. I tried wireless in the same Wi-Fi network first then tried to hardwire my laptop to Orbi as well so both were Ethernet and same issue.
      • CrimpOn's avatar
        CrimpOn
        Is the NAS connected directly to the Orbi router Ethernet port, or through a switch of some kind?
        I forget how Western Digital NAS systems are managed: is it through a web interface? or an "app" that goes out and finds the NAS?
