Speyerclan
Jun 21, 2025Aspirant
Orbi 860 mesh with 3 satellites devices failing to reconnect after router reboot.
I have a lot of Shelly devices about 90 odd. All smart home devices are connected to the LoT wifi, all have DHCP reserved addresses, had to do a reboot of the router after adding a reserved address ...
Jun 21, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Additional troubleshooting information: Orbi MESH Troubleshooting, Suggestions and Tips | NETGEAR Communities
